{"name":"","description":"","url":"https:\/\/motortuning-forum.de\/Chiptuning","home":"https:\/\/motortuning-forum.de\/Chiptuning","gmt_offset":2,"timezone_string":"Europe\/Berlin","namespaces":["oembed\/1.0","redirection\/v1","yoast\/v1","wp\/v2"],"authentication":[],"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/"}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"oembed\/1.0"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/oembed\/1.0"}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true},"format":{"required":false,"default":"json"},"maxwidth":{"required":false,"default":600}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/oembed\/1.0\/embed"}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true,"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string"},"format":{"required":false,"default":"json","enum":["json","xml"],"description":"Das zu verwendende oEmbed-Format.","type":"string"},"maxwidth":{"required":false,"default":600,"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer"},"maxheight":{"required":false,"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer"},"discover":{"required":false,"default":true,"description":"Ob eine oEmbed Discovery-Anfrage f\u00fcr Anbieter, die nicht auf der Whitelist stehen, ausgef\u00fchrt werden soll.","type":"boolean"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/oembed\/1.0\/proxy"}},"\/redirection\/v1":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"redirection\/v1"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1"}},"\/redirection\/v1\/redirect":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"required":false,"enum":["url","group"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","last_count","last_access","position","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["url","group"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","last_count","last_access","position","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/redirect"}},"\/redirection\/v1\/redirect\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/bulk\/redirect\/(?P<bulk>delete|enable|disable|reset)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["url","group"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","last_count","last_access","position","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"},"items":{"required":true,"description":"Comma separated list of item IDs to perform action on","type":"string|integer"}}}]},"\/redirection\/v1\/group":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"required":false,"enum":["name","module"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["name","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["name","module"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["name","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"},"moduleId":{"required":true,"description":"Module ID","type":"integer"},"name":{"required":true,"description":"Group name","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/group"}},"\/redirection\/v1\/group\/(?P<id>[\\d]+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"moduleId":{"required":true,"description":"Module ID","type":"integer"},"name":{"required":true,"description":"Group name","type":"string"}}}]},"\/redirection\/v1\/bulk\/group\/(?P<bulk>delete|enable|disable)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["name","module"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["name","id"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"},"items":{"required":true,"description":"Comma separated list of item IDs to perform action on","type":"string|integer"}}}]},"\/redirection\/v1\/log":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"required":false,"enum":["url","ip","url-exact"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","ip"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["url","ip","url-exact"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","ip"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/log"}},"\/redirection\/v1\/bulk\/log\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["url","ip","url-exact"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["url","ip","url-exact"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"},"items":{"required":true,"description":"Comma separated list of item IDs to perform action on","type":"string|integer"}}}]},"\/redirection\/v1\/404":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"filterBy":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}},{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/404"}},"\/redirection\/v1\/bulk\/404\/(?P<bulk>delete)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filterBy":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to filter by","type":"enum"},"filter":{"required":false,"description":"Value to filter by","type":"string"},"orderby":{"required":false,"enum":["ip","url","url-exact","total"],"description":"Field to order results by","type":"enum"},"direction":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Direction of ordered results","type":"enum"},"per_page":{"required":false,"default":25,"description":"Number of results per page","type":"integer"},"page":{"required":false,"default":0,"description":"Page offset","type":"integer"},"items":{"required":true,"description":"Comma separated list of item IDs to perform action on","type":"string|integer"}}}]},"\/redirection\/v1\/setting":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/setting"}},"\/redirection\/v1\/plugin":{"namespace":"redirection\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/plugin"}},"\/redirection\/v1\/plugin\/delete":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/plugin\/delete"}},"\/redirection\/v1\/plugin\/test":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/plugin\/test"}},"\/redirection\/v1\/import\/file\/(?P<group_id>\\d+)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/import\/plugin":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/redirection\/v1\/import\/plugin"}},"\/redirection\/v1\/import\/plugin\/(?P<plugin>.*?)":{"namespace":"redirection\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/redirection\/v1\/export\/(?P<module>1|2|3|all)\/(?P<format>csv|apache|nginx|json)":{"namespace":"redirection\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"yoast\/v1"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1"}},"\/yoast\/v1\/configurator":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1\/configurator"}},"\/yoast\/v1\/reindex_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1\/reindex_posts"}},"\/yoast\/v1\/ryte":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1\/ryte"}},"\/yoast\/v1\/indexables\/(?P<object_type>\\w+)\/(?P<object_id>\\d+)":{"namespace":"yoast\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":[]}]},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true,"description":"The url to retrieve","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1\/file_size"}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/yoast\/v1\/statistics"}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"required":false,"default":"wp\/v2"},"context":{"required":false,"default":"view"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2"}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"after":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"author":{"required":false,"default":[],"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string"},"slug":{"required":false,"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"}},"categories":{"required":false,"default":[],"description":"Ergebnissatz auf alle Elemente begrenzen, die in der Taxonomie categories einen bestimmten Begriff zugewiesen bekommen haben.","type":"array","items":{"type":"integer"}},"categories_exclude":{"required":false,"default":[],"description":"Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen, den der bestimmte Begriff in der categories-Taxonomie zugewiesen wurde.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"default":[],"description":"Ergebnissatz auf alle Elemente begrenzen, die in der Taxonomie tags einen bestimmten Begriff zugewiesen bekommen haben.","type":"array","items":{"type":"integer"}},"tags_exclude":{"required":false,"default":[],"description":"Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen, den der bestimmte Begriff in der tags-Taxonomie zugewiesen wurde.","type":"array","items":{"type":"integer"}},"sticky":{"required":false,"description":"Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean"}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"password":{"required":false,"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"excerpt":{"required":false,"description":"Der Textauszug f\u00fcr dieses Objekt.","type":"object"},"featured_media":{"required":false,"description":"Die ID des hervorgehobenen Mediums f\u00fcr das Objekt.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"format":{"required":false,"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"description":"Das Format des Objekts.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"sticky":{"required":false,"description":"Ob das Objekt als oben gehalten behandelt werden soll oder nicht.","type":"boolean"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"},"categories":{"required":false,"description":"Die Begriffe, die dem Objekt in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"description":"Die Begriffe, die dem Objekt in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"}}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/posts"}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"password":{"required":false,"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"password":{"required":false,"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"excerpt":{"required":false,"description":"Der Textauszug f\u00fcr dieses Objekt.","type":"object"},"featured_media":{"required":false,"description":"Die ID des hervorgehobenen Mediums f\u00fcr das Objekt.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"format":{"required":false,"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"description":"Das Format des Objekts.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"sticky":{"required":false,"description":"Ob das Objekt als oben gehalten behandelt werden soll oder nicht.","type":"boolean"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"},"categories":{"required":false,"description":"Die Begriffe, die dem Objekt in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"}},"tags":{"required":false,"description":"Die Begriffe, die dem Objekt in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"}}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","type":"boolean"}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["DELETE"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"after":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"author":{"required":false,"default":[],"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"menu_order":{"required":false,"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer"},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string"},"parent":{"required":false,"default":[],"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"}},"slug":{"required":false,"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"}}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"password":{"required":false,"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string"},"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"excerpt":{"required":false,"description":"Der Textauszug f\u00fcr dieses Objekt.","type":"object"},"featured_media":{"required":false,"description":"Die ID des hervorgehobenen Mediums f\u00fcr das Objekt.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"menu_order":{"required":false,"description":"Die Reihenfolge des Objekts im Verh\u00e4ltnis zu anderen Objekten seines Typs.","type":"integer"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/pages"}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"password":{"required":false,"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"password":{"required":false,"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string"},"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"excerpt":{"required":false,"description":"Der Textauszug f\u00fcr dieses Objekt.","type":"object"},"featured_media":{"required":false,"description":"Die ID des hervorgehobenen Mediums f\u00fcr das Objekt.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"menu_order":{"required":false,"description":"Die Reihenfolge des Objekts im Verh\u00e4ltnis zu anderen Objekten seines Typs.","type":"integer"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","type":"boolean"}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["DELETE"],"args":{"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"after":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"author":{"required":false,"default":[],"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"}},"before":{"required":false,"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string"},"parent":{"required":false,"default":[],"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"}},"slug":{"required":false,"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}},"status":{"required":false,"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"}},"media_type":{"required":false,"enum":["image","video","text","application","audio"],"description":"Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps begrenzen.","type":"string"},"mime_type":{"required":false,"description":"Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs begrenzen.","type":"string"}}},{"methods":["POST"],"args":{"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"},"alt_text":{"required":false,"description":"Alternativtext, der anzeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string"},"caption":{"required":false,"description":"Der Untertitel des Anhangs.","type":"object"},"description":{"required":false,"description":"Die Beschreibung des Anhangs.","type":"object"},"post":{"required":false,"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/media"}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Ressource, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"status":{"required":false,"enum":["publish","future","draft","pending","private"],"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string"},"title":{"required":false,"description":"Der Titel f\u00fcr das Objekt.","type":"object"},"author":{"required":false,"description":"Die ID f\u00fcr den Autor des Objekts.","type":"integer"},"comment_status":{"required":false,"enum":["open","closed"],"description":"Ob Kommentare f\u00fcr das Objekt ge\u00f6ffnet sind oder nicht.","type":"string"},"ping_status":{"required":false,"enum":["open","closed"],"description":"Ob das Objekt gepingt werden kann oder nicht.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"},"template":{"required":false,"description":"Die Theme-Datei, die zur Anzeige des Objekts benutzt wird.","type":"string"},"alt_text":{"required":false,"description":"Alternativtext, der anzeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string"},"caption":{"required":false,"description":"Der Untertitel des Anhangs.","type":"object"},"description":{"required":false,"description":"Die Beschreibung des Anhangs.","type":"object"},"post":{"required":false,"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","type":"boolean"}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/types"}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/statuses"}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"type":{"required":false,"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/taxonomies"}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"description":"Sammlung nach Begriffsattribut sortieren.","type":"string"},"hide_empty":{"required":false,"default":false,"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean"},"parent":{"required":false,"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer"},"post":{"required":false,"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer"},"slug":{"required":false,"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}}}},{"methods":["POST"],"args":{"description":{"required":false,"description":"HTML-Beschreibung des Begriffs.","type":"string"},"name":{"required":true,"description":"HTML-Titel f\u00fcr den Begriff.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/categories"}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"description":{"required":false,"description":"HTML-Beschreibung des Begriffs.","type":"string"},"name":{"required":false,"description":"HTML-Titel f\u00fcr den Begriff.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"description":"Sammlung nach Begriffsattribut sortieren.","type":"string"},"hide_empty":{"required":false,"default":false,"description":"Ob Begriffe verborgen werden, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean"},"post":{"required":false,"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer"},"slug":{"required":false,"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}}}},{"methods":["POST"],"args":{"description":{"required":false,"description":"HTML-Beschreibung des Begriffs.","type":"string"},"name":{"required":true,"description":"HTML-Titel f\u00fcr den Begriff.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/tags"}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"description":{"required":false,"description":"HTML-Beschreibung des Begriffs.","type":"string"},"name":{"required":false,"description":"HTML-Titel f\u00fcr den Begriff.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer"},"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"asc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"name","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string"},"slug":{"required":false,"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"}},"roles":{"required":false,"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder einzelne Rolle.","type":"array","items":{"type":"string"}},"who":{"required":false,"enum":["authors"],"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string"}}},{"methods":["POST"],"args":{"username":{"required":true,"description":"Anmeldename f\u00fcr den Benutzer.","type":"string"},"name":{"required":false,"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string"},"first_name":{"required":false,"description":"Vorname f\u00fcr den Benutzer.","type":"string"},"last_name":{"required":false,"description":"Nachname f\u00fcr den Benutzer.","type":"string"},"email":{"required":true,"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string"},"url":{"required":false,"description":"URL des Benutzers.","type":"string"},"description":{"required":false,"description":"Beschreibung des Benutzers.","type":"string"},"locale":{"required":false,"enum":["","en_US","de_DE"],"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string"},"nickname":{"required":false,"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string"},"roles":{"required":false,"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"}},"password":{"required":true,"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/users"}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer"},"username":{"required":false,"description":"Anmeldename f\u00fcr den Benutzer.","type":"string"},"name":{"required":false,"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string"},"first_name":{"required":false,"description":"Vorname f\u00fcr den Benutzer.","type":"string"},"last_name":{"required":false,"description":"Nachname f\u00fcr den Benutzer.","type":"string"},"email":{"required":false,"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string"},"url":{"required":false,"description":"URL des Benutzers.","type":"string"},"description":{"required":false,"description":"Beschreibung des Benutzers.","type":"string"},"locale":{"required":false,"enum":["","en_US","de_DE"],"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string"},"nickname":{"required":false,"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string"},"roles":{"required":false,"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"}},"password":{"required":false,"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer"},"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"},"reassign":{"required":true,"description":"Die gel\u00f6schten Beitr\u00e4ge und Links des Benutzers dieser Benutzer-ID erneut zuweisen.","type":"integer"}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"required":false,"description":"Anmeldename f\u00fcr den Benutzer.","type":"string"},"name":{"required":false,"description":"Anzeige-Name f\u00fcr den Benutzer.","type":"string"},"first_name":{"required":false,"description":"Vorname f\u00fcr den Benutzer.","type":"string"},"last_name":{"required":false,"description":"Nachname f\u00fcr den Benutzer.","type":"string"},"email":{"required":false,"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string"},"url":{"required":false,"description":"URL des Benutzers.","type":"string"},"description":{"required":false,"description":"Beschreibung des Benutzers.","type":"string"},"locale":{"required":false,"enum":["","en_US","de_DE"],"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string"},"nickname":{"required":false,"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string"},"slug":{"required":false,"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string"},"roles":{"required":false,"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"}},"password":{"required":false,"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}},{"methods":["DELETE"],"args":{"force":{"required":false,"default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","type":"boolean"},"reassign":{"required":true,"description":"Die gel\u00f6schten Beitr\u00e4ge und Links des Benutzers dieser Benutzer-ID erneut zuweisen.","type":"integer"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/users\/me"}},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"page":{"required":false,"default":1,"description":"Aktuelle Seite der Sammlung.","type":"integer"},"per_page":{"required":false,"default":10,"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer"},"search":{"required":false,"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string"},"after":{"required":false,"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"author":{"required":false,"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"}},"author_exclude":{"required":false,"description":"Stelle sicher, dass der Ergebnissatz Kommentare ausschlie\u00dft, die einer bestimmten Benutzer-ID zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"}},"author_email":{"required":false,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","type":"string"},"before":{"required":false,"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string"},"exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"include":{"required":false,"default":[],"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"}},"offset":{"required":false,"description":"Verschiebt den Ergebnissatz um eine bestimmte Elementanzahl.","type":"integer"},"order":{"required":false,"default":"desc","enum":["asc","desc"],"description":"Attribut f\u00fcr aufsteigende oder absteigende Sortierung.","type":"string"},"orderby":{"required":false,"default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"description":"Sortiere die Sammlung nach einem Attribut des Objekts.","type":"string"},"parent":{"required":false,"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"}},"parent_exclude":{"required":false,"default":[],"description":"Stelle sicher, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"}},"post":{"required":false,"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"}},"status":{"required":false,"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string"},"type":{"required":false,"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string"},"password":{"required":false,"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string"}}},{"methods":["POST"],"args":{"author":{"required":false,"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer"},"author_email":{"required":false,"description":"E-Mail-Adresse f\u00fcr den Autor des Objekts.","type":"string"},"author_ip":{"required":false,"description":"IP-Adresse f\u00fcr den Autor des Objekts.","type":"string"},"author_name":{"required":false,"description":"Anzeige-Name f\u00fcr den Autor des Objekts.","type":"string"},"author_url":{"required":false,"description":"URL f\u00fcr den Autor des Objekts.","type":"string"},"author_user_agent":{"required":false,"description":"User agent f\u00fcr den Autor des Objekts.","type":"string"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"parent":{"required":false,"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"post":{"required":false,"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer"},"status":{"required":false,"description":"Zustand des Objekts.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/comments"}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"context":{"required":false,"default":"view","enum":["view","embed","edit"],"description":"Geltungsbereich der Anfrage; ermittelt in der Antwort vorhandene Felder.","type":"string"},"password":{"required":false,"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string"}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"author":{"required":false,"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer"},"author_email":{"required":false,"description":"E-Mail-Adresse f\u00fcr den Autor des Objekts.","type":"string"},"author_ip":{"required":false,"description":"IP-Adresse f\u00fcr den Autor des Objekts.","type":"string"},"author_name":{"required":false,"description":"Anzeige-Name f\u00fcr den Autor des Objekts.","type":"string"},"author_url":{"required":false,"description":"URL f\u00fcr den Autor des Objekts.","type":"string"},"author_user_agent":{"required":false,"description":"User agent f\u00fcr den Autor des Objekts.","type":"string"},"content":{"required":false,"description":"Der Inhalt des Objekts.","type":"object"},"date":{"required":false,"description":"Das Datum der Ver\u00f6ffentlichung des Objekts, in der Zeitzone der Website.","type":"string"},"date_gmt":{"required":false,"description":"Das Datum in GMT, an dem das Objekt ver\u00f6ffentlicht wurde.","type":"string"},"parent":{"required":false,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer"},"post":{"required":false,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer"},"status":{"required":false,"description":"Zustand des Objekts.","type":"string"},"meta":{"required":false,"description":"Metafelder.","type":"object"}}},{"methods":["DELETE"],"args":{"id":{"required":false,"description":"Eindeutige Kennung f\u00fcr das Objekt.","type":"integer"},"force":{"required":false,"default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","type":"boolean"},"password":{"required":false,"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string"}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"required":false,"description":"Website-Titel.","type":"string"},"description":{"required":false,"description":"Website-Untertitel.","type":"string"},"url":{"required":false,"description":"Website-URL.","type":"string"},"email":{"required":false,"description":"Diese Adresse wird f\u00fcr administrative Zwecke verwendet, wie Benachrichtigungen \u00fcber neue Benutzer.","type":"string"},"timezone":{"required":false,"description":"Eine Stadt in deiner Zeitzone.","type":"string"},"date_format":{"required":false,"description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string"},"time_format":{"required":false,"description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string"},"start_of_week":{"required":false,"description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer"},"language":{"required":false,"description":"WordPress-L\u00e4ndercode.","type":"string"},"use_smilies":{"required":false,"description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean"},"default_category":{"required":false,"description":"Standard-Beitragskategorie.","type":"integer"},"default_post_format":{"required":false,"description":"Standard-Beitragsformat.","type":"string"},"posts_per_page":{"required":false,"description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer"},"default_ping_status":{"required":false,"enum":["open","closed"],"description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string"},"default_comment_status":{"required":false,"enum":["open","closed"],"description":"Besuchern erlauben, neue Beitr\u00e4ge zu kommentieren.","type":"string"}}}],"_links":{"self":"https:\/\/motortuning-forum.de\/Chiptuning\/wp-json\/wp\/v2\/settings"}}},"_links":{"help":[{"href":"http:\/\/v2.wp-api.org\/"}]}}
